Correcting Fast blink after switching to LED's?
#22
Man Motor club
1 Post
load resistors.. i posted this a while back, only difference is my switchbacks are now orange-off-orange, instead of the white staying on when signalling...much safer.
https://www.performancetrucks.net/fo...-pics*-501149/
#23
I believe a few of use was hoping to find out another way of achieving this beside resistors kinda explains talking about to BCM getting programmed. On the nbs all you have to do is change the flasher. I know I would rather not splice into my harness and solder some cheap resistors that get hot as hell next to the harness or the plastic head light housing IMO.
#26
And yes a few seem to miss the point of my original post. I know resistors will work but if all it takes is a quick reprogram I would much rather do that than hook up a bunch of resisters
#27
#30
its simple electronoics, led are diodes which only use .7 volts. the computer doesnt see any current draw 20 you will need a resistor. a simple reprogram wont remap the circuit. power will always take the path or lease resistance. it takes 1 volt to push 1 amp throught a 1 ohm resistor.
