Denali 6.2 WOT Problems
Old 05-22-2009 | 12:36 PM
lownslo's Avatar
looks like a ground issue.... i had the same thing happen to me when i did the motor swap.....a ground was not attached and one was in the wrong place causing it not to make a good connection! If you have taking off any grounds or poss. check grounds on the batt. and fuse block for loose connection!
If that doesnt help then the stealership will have to proccess that one!
Good luck
Old 05-22-2009 | 01:24 PM
norris_83's Avatar
thanks for the reply.. thats what i was thinking, but didn't want to take it to the dealer coz i know the dealers here are gonna blame the mods... im taking it to a friends garage tmrw, hopefully find out what the problems are...
Old 05-22-2009 | 02:00 PM
GMCtrk's Avatar
anytime something very odd goes wrong think ground, lowslow is right on. You mentioned that the mechanics there aren't very knowledgable on the work they did for you so I'm guessing something didn't go back properly or maybe a ground wasn't tightened good enough and it came loose over time.
Tydriver
45
10-23-2015 09:19 PM
Brandonlflr12
14
09-16-2015 12:44 AM
lsxperformance
09-15-2015 10:22 PM
Justin87gn
09-10-2015 12:06 PM
Pimpinpete
09-08-2015 07:39 PM
Quick Reply: Denali 6.2 WOT Problems
