DIC switch
Old 12-22-2008 | 03:48 PM
Rage_89's Avatar
Very nice! Looks like I get something else for x mas.
Old 12-22-2008 | 04:49 PM
LawmanSS's Avatar
Glad to help!
It really is a great mod and I agree, it's really cheesy of the General not to throw in the $14 switch.
Old 12-22-2008 | 08:25 PM
Z06.0's Avatar
could I do this with an 07 cobalt?
Old 12-22-2008 | 08:32 PM
Z06.0's Avatar
disregard that last statement i just clicked the link lol
Old 12-22-2008 | 09:36 PM
Trey's Avatar
Will this work on w/t models also?
Old 12-22-2008 | 10:03 PM
LawmanSS's Avatar
I can't say for sure that it will work on W/T models. You could remove the trim panel to the left of the instrument cluster and check for the wiring harness. It's the panel that has the HVAC vent and the headlight switch. If you have the DIC wiring, it will be plugged into the back of the panel into a dummy connector...look for the wiring that goes to nowhere!
Old 12-23-2008 | 07:26 AM
nighthawk08's Avatar
yes, it will work on WT models.
Old 12-24-2008 | 11:37 PM
Rage_89's Avatar
Post some pics when you get it all set up. How exactly does the headlight **** come off? Mine looks as if you can pull the panel off and not mess with the switch itself. I surely don't need to screw it up, it's too new for that.
Old 12-29-2008 | 02:03 PM
Occupational_Hazard's Avatar
just curious but if you just by the switch, guess you gotta cut a hole through original panel?
Old 12-29-2008 | 04:50 PM
LawmanSS's Avatar
Judging by the way the hole is laid out and the retention tabs that are molded on there to hold the switch, cutting your own hole would not work. You're going to need to buy the correct panel...
Quick Reply: DIC switch
