Displacement On Demand
Old 02-28-2010, 01:10 PM
supercharged680's Avatar
Talking Displacement On Demand
hey there guys.. 2 questions here.. how do u knw that ur truck has DOD (4 and 8 cylinder modes ) should it say flex fuel? or not..
what are the pros and cons vs keeping and disabling it..
Ahmad.
Old 02-28-2010, 06:39 PM
skipperdaddy's Avatar
Its actually called AFM... active fuel management... if u have that u have DOD...
Old 02-28-2010, 07:31 PM
iamkeniff's Avatar
get rid of it!
theres a parta list that you need to get to get rid of the DOD...good luck
Old 02-28-2010, 08:20 PM
Allgonoshow's Avatar
if you have it, there is a notice in the drivers info center when it kicks in.
says 4cyl mode or something like that.
advantage, slightly better fuel economy
disadvantage, truck sounds like crap running on 4cyl if you have performance exhaust
it can be disabled in your tune with hpt
Old 03-01-2010, 08:02 AM
a_guerrajr's Avatar
Originally Posted by iamkeniff
get rid of it!
is disabling it with a tune the same as physically removing it with parts?
Old 03-01-2010, 08:15 AM
iamkeniff's Avatar
nope
the DOD lifters cant handle a cam unless the cam is spec'd for DOD which i dont see a point in.
change all 16 lifters, 4 lifter trays, 2 head gaskets, crank bolt, head bolts
Old 03-01-2010, 08:18 AM
nope
the yukon denali doesnt have DOD right?
Old 03-01-2010, 08:44 AM
13 Second Truck Club
markislive78's Avatar
According to the GM specs it does...
http://archives.media.gm.com/us/powe...k/10_L94_n.xls
What's interesting is that 2009-2010 SUV and Trucks show a different engine code. Truck have and L99 and SUV's have a L94. L94 data sheets shows "Active Fuel Management as an option. In 07-08 all SUV and trucks had L92.
Old 03-01-2010, 10:12 AM
iamkeniff's Avatar
i cant tell you...my 6.2 has VVT but im
changing lifters anyways bc its only advised to run to 5900rpm. im
spinning 6200-6300 depending where my cam stops pulling.
Old 03-02-2010, 06:31 PM
Banned
gm327's Avatar
' Get rid of the dod ... Those dod lifters suck' they are engine killers' I had my dod. Removed from my tunner ' but those lifters cannot handle above 6000 rpm' eventually failing at high lift cam and rpm's .. Change to ls7 lifters and valley cover
Quick Reply: Displacement On Demand
