dod delete kit
Old 09-17-2010 | 01:16 AM
  #31
Swipez08's Avatar
Originally Posted by Preston129
Exactly, things don't typically break on their own. You could ask why GM puts driveshafts that aren't balanced to handle 100+MPH, well, most people won't have a need to go over that speed.
lol ive done 130+ in my truck with a stock drive shaft..but 2 of my buddies broke theirs around 105-110..i think it jus depends on what the techs mood was in that day.. jus like wen u get a "factory freak". sometimes **** just works
Old 09-21-2010 | 12:21 AM
  #32
Fastlane50's Avatar
anyone have the part number for the OEM crank bolt? how about the part number for the ARP crank bolt? I also need part numbers for the OEM exhaust manifold gaskets, and OEM exhaust manifold bolts.
Old 09-21-2010 | 02:48 AM
  #33
Preston129's Avatar
ARP bolt: 234-2503
This is the exhaust manifold gasket I ordered: 12617944
I'm going to be using Percy's split lock header bolts, so can't help you with those part numbers, although they shouldn't be hard to source from a dealership.
Old 09-21-2010 | 07:15 AM
  #34
iamkeniff's Avatar
i upgraded to the ARP crank bolt, head bolts, i reused my stock exhaust gaskets (im also on my 2nd motor) i upgraded to 12 point stainless steel bolts with lock washers. they've been great to me on both my trucks so i went back with them.
Old 11-14-2010 | 10:46 PM
  #35
double047's Avatar
14 Second Truck Club
Wow, thanks for making this thread guys.
Old 02-09-2011 | 11:24 PM
  #36
08cheyennesc's Avatar
Originally Posted by Mrgoodwrench3
The parts can be purchased separately at gmpartsdirect.com
LS7 lifters 12499225
Lifter trays 12595365
Valley cover 12570471
Sprocket 12586481
Dampener 12588670
I would recommend ARP head bolts. 134-3610 best price on ebay. I paid $91.00
The GEN4 5.3 has the larger 90mm 4 bolt throttle body.
I'm getting ready to order parts for my DOD delete / Cam install , does anyone knows what else I will need for the DOD delete beside the list above? Will I need new seals/gaskets?
Old 02-09-2011 | 11:49 PM
  #37
two-piece's Avatar
Get water pump and head gaskets and a new crank bolt.
Old 02-10-2011 | 08:48 AM
  #38
JAVI05's Avatar
what are you guys spending on all this??? all done tune and all???? with an aftermarket cam? thanks.
Old 02-10-2011 | 05:49 PM
  #39
two-piece's Avatar
anywhere from 1200-1500 depending on tuner and where you get all the parts.
Old 02-10-2011 | 06:20 PM
  #40
Onetogofast's Avatar
What does DOD stand for, does it relate to the VVT at all?
Quick Reply: dod delete kit
