Dod delete part list
esoteric_ast (10-09-2019)
#56
I copied this from my cam swap thread, but I thought it would be easier for folks to find here. These are all of the parts I used IIRC.
-ISKY Triple 12 (Stock 48 $389 shipped)
-LS7 lifters (GM 17122490 $129)
-Alper Head studs (GEN IV head studs $109.50)
-BTR hardened pushrods (PR7350312-16 $94)
-LS9 head gaskets (GM 12622033 $47 EACH)
-TSP Ported LS6 oil pump (25-TspPortedPump $189)
-LS2 timing chain (GM 12646386 $40)
-LS2 tensioner (GM 12588670 $15.61)
-4x 3 bolt cam gear (GM 12586481 $26)
-Arp cam bolts (ARP 134-1003 $9.30)
-LS2 lifter trays (GM 12595365 $8 EACH x4)
-BTR springs (SK001 $229)
-Comp trunion upgrade (13702-KIT $131)
-ARP crank bolt (234-2503 $27.99)
-LS7 crank bolt to put balancer on (GM 11570163 $8.50)
-4.8L valley cover (GM 1259832 $42)
-10' 5/8" heater hose
-2 brass 3/4" elbows (all Home Depot had and they work fine)
-2 brass 3/4" couplings
-hose clamps
-new gaskets all around except valve cover and int/exh manifolds (TSP 28-CamGskKit $61.99)
-Arp thread tap
-mineral spirits and plastic scraper for cleaning head surfaces
TOTAL $1,627.93. This doesn't include the misc stuff I bought at the auto parts store like spark plugs, fluids etc.
-hose clamps
-Arp thread tap
#58
this is a list to do a DOD delete on a 5.3, the same thing would go for the 6.0 and 6.2 but you would need L92 head gaskets *ONLY IF IT HAS DOD ALSO* but you'd have to purchase the front cover.
LS2 timing cover sensor gasket and seal 12633906 (only needed if you have VVT)
Cam Gears *there are 2 options*
Single bolt *you already have this cam gear if you have a 4.8/5.3*
3 bolt
Part Number: 12586481
Head Gaskets
Part Number: 12498544 *this is for 2 5.3 head gaskets, not the single pack*
LS7 Lifters
Part Number: 12499225
LS2 Dampener *i recommend to swap this because the factory tension is JUNK*
Part Number: 12588670
Lifter Guide *you need 4 of these*
Part Number: 12595365
Valley Cover *without AFM and without the PVC vent (known as the 4.8 valley cover. it is just like the LS3/7 valley cover just half the price)*
Part Number: 12598832
LS9 head gasket: 12622033 *you need 2*
L92/LS3 (6.2) head gasket: 12610046 *you need 2*
6.0 head gasket: 12589227 *you need 2*
info added from AUTOT3K
non VVT front cover: 12633906 (only needed if you have VVT)
Various Gaskets
Water Pump X 2 12630223
Valve Cover X 2 12637683
Oil Pump O-Ring 12584922 - orange
ARP Head Bolts for 05+ block 134-3610
ARP LS crank bolt (except LS7) 234-2503
ARP cam retainer plate bolts 134-1002
ARP cam sprocket bolts 134-1003
Your total for the cam/dod delete with parts will range about 1600-1700 depending where you can save on costs
3 bolt
Head Gaskets
LS7 Lifters
Various Gaskets
Also does everyone recommend going all ARP, or with New OEM bolts?
5.3Caprice
11-07-2015 08:56 PM
