Drive shaft specs to build
Old 02-13-2013, 12:27 AM
JCunningham's Avatar
Default Drive shaft specs to build
Any one have the specs I could send to a place local to have a better shaft made for my 12 4x4 6.2L extended cab 6.5" bed .
Old 02-13-2013, 05:44 AM
03sierraslt's Avatar
Like what, you need to measure yours not someone else's.
Old 02-13-2013, 11:36 AM
id assume everyone els that has a the same truck I have would have the same driveshaft. and maby some one knows the dimensions to give the shop to make one. Its better then me driving it 35miles to the shop and crawling under it. I was thinking after I posted this I could probably drive to Fleet Pride and maybe they could measure it.
Old 02-13-2013, 12:26 PM
Robert91RS's Avatar
4x4 or AWD?
Old 02-13-2013, 12:28 PM
it has 2wd, AWD 4 hi 4low and neutral
Old 02-13-2013, 01:24 PM
Robert91RS's Avatar
See if I can get you a measurement. It is a 9.5" diff correct?
Old 02-13-2013, 01:31 PM
Ya 9.5 thanks
Old 02-13-2013, 01:37 PM
Robert91RS's Avatar
Nothing in a bay at the moment, but I'll keep my eye out and let you know if I get one in.
Old 02-13-2013, 08:56 PM
CodyG's Avatar
thought it was only the 2wd trucks with drive shaft failures? The 4x4 trucks are safe, right?
Old 02-13-2013, 09:05 PM
No, any of the EC/CC are prone.
Quick Reply: Drive shaft specs to build
