Driveshaft info
Old 02-28-2011 | 11:12 PM
Atomic's Avatar
I have a gauge for that
The factory builds them to handle factory trucks. Its when you start pushing 100+mph where you run into big problems.
Old 02-28-2011 | 11:34 PM
EVILGMC's Avatar
I run steel with 1350s at both ends.
Old 03-01-2011 | 12:04 AM
rjwz28's Avatar
Man Motor club
What about the 6.2 trucks? Obviously we have the same speed limiter, but is there a difference in the 100+ mph performance of our driveshafts?
Old 03-01-2011 | 12:12 AM
smokeshow's Avatar
Mod with training wheels
There could be. I honestly wouldn't trust any factory driveshaft again after I saw what GM did with my truck. The stock tune had the speed limiter set at 90mph, and I couldn't figure out why until I got it removed and ran into an absolutely brutal vibration at like 93mph. They are typically set at 98, but it certainly looks as if GM tried to hide the error on my truck. Scary thought...
Old 03-01-2011 | 12:53 AM
rjwz28's Avatar
Man Motor club
Wow, that is scary! Mine hits 98mph quick, fast, and in a hurry, no hesitation, vibration, or other issues. If I can go 120 on it, I'd be totally satisfied. What kind of money and driveshaft options are we looking at for 120+mph, 500hp, and 33" tires on my truck (planning ahead)?
Old 03-01-2011 | 07:06 PM
schino's Avatar
do you have 1 pc? driveshaft shop in texas that was mentioned will run you around 450 for a 5" dia alum 1 pc. its what im looking to get for mine
Old 03-02-2011 | 12:22 AM
fast84's Avatar
The first shaft twisted exactly in the middle and tore up $1500 worth of crap. That was at 90ish with no lowering and stock 3.42's. The second one made it to 110ish if I remember correctly with the reared lowered and 4.10's. Both shafts were factory. The one I have now is a 3.5" steel shaft but having u joint trouble on rear and I want it high speed c
Balanced. Gonna try Jackson Powertrain in Jackson,Ms. Had one of our members give them a good referral.
Old 03-02-2011 | 02:07 PM
rjwz28's Avatar
Man Motor club
My factory driveshaft is a pretty large one-piece that appears to be aluminum. If that is a problem over 100mph just like all the other trucks, I guess that will also be on my short list of things to replace before a tune.
RustyD
05-23-2016 07:04 PM
turbo6c3
10-05-2015 06:11 PM
slimchevy2
10-04-2015 08:02 PM
Wolftrk99
10-02-2015 08:17 AM
jscherbs
09-30-2015 07:54 AM
Quick Reply: Driveshaft info
