drop
drop
ok like it said i have the 5in dim rear flip kit and i have it set up where its on the 4 in drop setting i wana go down to the five part but from what it looks like it won't fit. the holes don't line up with each other... am i doing something wrong . i wana move it to the bottom hole I'm assuming thats the hole you put it in for the 5 drop. unless I'm wrong and already have 5 in the back
4-5" DJM drop kit here... hole closest to the end of the hanger is 4", hole further up is for 5"
see if the loop end on your leaf spring there is hitting the U up in the hanger. Both sides were hitting on mine.
I had to take a small grinder to the U where the leaf was hitting (which was keeping it from aligning for the bolt)
red arrows pointing to where mine were hitting
green circle is about how much I had to grind out.
It was ******* frustrating for 2 hrs before I realized it was hitting there.
thanks man ill give it a shot
