drop shackles
Old 10-16-2013 | 10:24 PM
craigsix's Avatar
Default drop shackles
i tried installing belltech 2 inch drop shackles tonite. the stock top shackle bolt would not clear the frame. i tried jacking up on the shock but it touchd the bed before it would clear. i guess i have to cut into the seam of the bed or unless theres a trick to getting it out. any input would be helpful. its a 2012 rcsb thanks.
Old 10-16-2013 | 10:37 PM
mdwatts11's Avatar
Loosen the 4 rear bed mounts about an inch and jack up the axle to push the bed up via the shackles.
Old 10-17-2013 | 09:33 PM
craigsix's Avatar
thank you sir.
Old 10-17-2013 | 10:19 PM
RacinRust's Avatar
Thats the best way!
You may also want to bend the seams over a little bit to clear the spring eyes so the wont rub and squeak.
BTW have you thought about a rear sway bar?
Old 10-19-2013 | 08:31 PM
craigsix's Avatar
i removed the 4 rear bed bolts and loosened the front 4. no problems. thank you mdwatts11.
Old 10-19-2013 | 11:31 PM
mdwatts11's Avatar
No problem!
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
Chewy07
11-14-2015 09:46 PM
Gadgetized
10-22-2015 09:06 AM
vmaxpro
09-28-2015 11:10 AM
twake_410
09-25-2015 10:09 PM
Quick Reply: drop shackles
