GMT-900 oil pressure relief valve delete
Old 04-19-2016 | 11:16 PM
iamkeniff's Avatar
Default GMT-900 oil pressure relief valve delete
As many LS3 guys have been doing once they delete their dod/vvt stuff, i felt it was needed on my non dod/vvt 6.2
I have been putting it off for a while, yet i had some free time and decided to tackle it.
Super easy. About an hour job with my 2wd truck.
I see an idle oil pressure of 48-50 now vs the 43-48. About 1500+ i see 58-60. I have yet to be WOT, so i don't know the max oil pressure i see. I know about 3/4 throttle i see about 65-68psi
I didn't think to take a before install and after install picture so i just used one from a google search
I ordered a Dorman Oil Drain Plug w/Gasket 090-154 - M14-1.5
Old 04-19-2016 | 11:21 PM
Wolftrk99's Avatar
Been wondering if gen 3 oil pan would accomplish the same thing???
Old 04-19-2016 | 11:28 PM
iamkeniff's Avatar
It could i think, yet we don't have the low oil level sensor in our pans. Well atleast the ones i've seen don't.
The plug was about 5.00 so i would have had to chase down a pan
Old 04-19-2016 | 11:34 PM
Wolftrk99's Avatar
Thats a good point..... Im still debating the vvt vs non vvt thing at the moment for my yukon.... Afm is going away, without a doubt but if i decide to add vvt i will need to keep the relief in the pan, if not i will end up deleting it...
Old 04-21-2016 | 11:50 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Mine has a low oil level sensor. I used a pipe plug and see 70+ psi at 3k rpm. The gen 3 pan has the drain on the side right onto the frame. All gen 4 motor oil pans have this relief valve.
Old 04-21-2016 | 11:57 PM
Wolftrk99's Avatar
Im confused what you mean about the gen 3 drain?? The gen 3 drain plug is at the back of the pan the gen iv are on the side... The gen 4 has sway bar at the back of the pan but no real frame that i remember...
Old 04-22-2016 | 05:34 AM
iamkeniff's Avatar
A pipe plug for the oil relief? That's not a horrible idea, but how did you seal the threads and not fear of hurting the engine? I like this drain plug because it has a copper gasket
Last edited by 03sierraslt; 04-22-2016 at 06:36 AM. Reason: Hit Edit instead of quote.... duh
Old 04-22-2016 | 06:36 AM
03sierraslt's Avatar
How would it hurt the engine? The tiny little bit that may seep past the threads ( if at all).
Old 04-22-2016 | 11:13 AM
iamkeniff's Avatar
I was mainly asking about any "sealant" if any was used.
I doubt it'd be noticed if nothing was used on them considering it's already getting more oil pressure to it.
Old 04-22-2016 | 11:46 AM
RS/SS 4.8's Avatar
Wolftrk99 your right i had em backwards. Thread sealer. The factory valve has some on it so i added some to the plug.
Quick Reply: GMT-900 oil pressure relief valve delete
