GMT900 Rear Gear Issues..
Would these gears fit our GMT 900 trucks? Talk about a deal - this kit is for both front and rear axles. If this works, I'm going to buy a set for my truck ASAP!
http://www.ronsmachiningservice.net/...VY-8.25/Detail
It looks as if the pinion bearing seat area is different on my factory pinion compared to the 90 1500 gears I pulled. There is about 3/4" of inch of machined area on the 90 1500 gear, and the 1.25" or more on the 2010 1500 pinion gear, due to the bigger bearing outside diamter.
The pinion bearing id size seems to be the same, but the outside diamater is alot bigger in my newer style rear.
**** the stealership. Gears can run as low as $130.00 for no namers and typically no more than $2-500 for OEM depending on application. Search ebay a lot of times you'll find a good dealer on there.
If you have a coo coo clock posi ( gov lock ) ditch that while your at it and throw in an Eaton.
Not saying that these are name brand gears, but ebay does have a lot of options for pretty cheap. I found some gears and eaton/auburn limited slips for around $625 to $675 for the kit together with intall kits. Just an option
And from a friend of mine locally that works at a dealership..
I work in GM Parts at Rentschler Chevrolet. The carrier bearings #25824250 fit 99-11 CK Truck 8.625 only and the pinions otr #25824252 fit 07-11 CK Truck 8.625 only, inr #25824251 07-11 CK Truck. The locking diff # 25902687 fits 99-11 CK Truck, 03-11 G-Van, 02-09 Trailblazer.
