GMT900 Rear Gear Issues..
Old 10-07-2010 | 03:50 PM
  #21
Poopra's Avatar
Originally Posted by CI DENALI
Does this mean that I can reuse the factory bearings from my truck and install these older style gears in my truck?
I pulled 3.42s today from an 01 van. They weren't even close and they had the bigger bearings...I put the pinion in exactly how I pulled it from the van and it sits sloppy.
edit - 01 vans are 8.5 style still.
Old 10-10-2010 | 10:16 PM
  #22
CI DENALI's Avatar
Does anyone have part numbers for aftermarket gears that can fit the AWD Denali?
Old 10-11-2010 | 12:11 AM
  #23
1Bear's Avatar
Not being smart by any means, but they are the same as the same corresponding year 4WD. That’s not to say that you have to buy by specific year model, but year model types. The front is just the typical 8.25” differential, in which the center section is the same between the AWD/4WD vehicles. The rear, is there again just typical to the other ½ ton trucks the Denali is based off of.
Old 10-11-2010 | 07:00 AM
  #24
CI DENALI's Avatar
Ok, I get that. But when I look at the prices for the 4WD gears on GM online, the list price is like $600+ for the fronts and $400 for the rear, and that's just the ring and pinion sets. I was hoping that someone on here could say what gears from motive, yukon etc. works in the GMT 900 AWD/4WD and what bearings are needed. My main concern is whether the pinion shaft diameter (on either the front or rear) is bigger, or is it just that the O/D of the pinion bearing is bigger? In other words, can the GMT 900 bearings fit on the older style gears, so that the older gears can work in the new trucks? I guess I just need to bite the bullet and give one of the gear companies a call. I want to make sure I order the right ones, because I would have to ship them overseas and pay import tax, so its not even practical to return them if they are wrong. When I find out, I will post the part #s, because there still seems to be a bit of confusion about whether the pinion bearings, diff bearings etc. are a different size.
Old 10-11-2010 | 04:07 PM
  #25
Poopra's Avatar
Just wanted to update. I had my old bearing pressed off my stock pinion (the rear cage part of the pinion was kinda bent after this). Measured my shim it was 36 thousandths. Measured my 1990 truck pinion shim I got from the junkyard and it was 35 thousandths (figured they were set up similar in the first place..but wanted to see). Put my stock 36 thousandths shim on the junkyard 1990 4.10 pinion, and had nothing to lose so I pressed on my old bearing. I took note of where the one carrier shim on left side and right side when I pulled it apart. Impacted everything together because I don't care (was pissed my truck sat for a week) and all is good!
Glad I didn't go 3.73. Stock is 3.23 on my truck.
Like I said, I was worried about my pinion bearing seat height at first, but it looked totally fine.
Go to the junkyard and grab some gears.
Old 10-11-2010 | 04:18 PM
  #26
Poopra's Avatar
Also..99+ center carriers on pickups have the bigger bearings (8.6 style).
I assume its 03 vans (lsx based engines, not spyder injection gen II) that have the bigger carrier bearings (8.6 style)
I pulled my gears from an "8.5" 1990 1500 2wd.
I do know the 09+ gmt900 (not the 07 or 08) have different pinion bearings on the inner (pinion pressed) and Im pretty sure the outer is different.
All of the pinion shafts are 1.626 or whatever. I don't know where that is measured but I know the gears will work in either application.
As far as the front differential..I'd almost bet if its 8.2 or whatever the 4wd trucks are you should be fine. Just make sure to use the specific pinion bearings for your applications. (99-08) or (09-11)..
Old 10-11-2010 | 05:12 PM
  #27
CI DENALI's Avatar
Hey thanks a bunch, man! That is very useful info there! I'm going to gamble a bit and order the set from Ron's Machine. I think you are right and they will work. Sounds like you like those 4.10s, huh?!
Old 10-11-2010 | 06:02 PM
  #28
viciousknid's Avatar
Where's the Beef?
From my reply on Post # 3
Perhaps I should have been more clear.
Originally Posted by viciousknid
PM Rons Machining services here on the site and they'll get you squared away. I get my gears thru him. I re-used my stock pinion bearings.
If you can't use what you have make sure you get a quality brand like Motives.
Old 10-15-2010 | 06:46 AM
  #29
ig109's Avatar
For what its worth the gears that i installed in my truck were originally ordered for a 1979 Trans Am..
Old 03-19-2011 | 08:46 AM
  #30
Banned
where is the best place to get the inner bearing.
gm 25824251, dealer wants $123.00
gnasty1521
35
11-19-2015 11:42 PM
Noah Burns
10-05-2015 06:46 AM
DarkhorSe_SS
08-20-2015 08:58 AM
USMCvet0311
08-14-2015 10:28 PM
MileHighSierra
07-22-2015 11:19 PM
Quick Reply: GMT900 Rear Gear Issues..
