guys that have stabilitrak
Old 04-21-2008, 11:30 AM
Y2KLimited's Avatar
its the same as active handling on vettes, thats the way that works on C6's (05 and up)
of course my sub has every damn option but no stabilitrak
this is a camera phone....both of us morons forgot cameras....my buddy was pissed because his wive's range rover couldn't turn off the stabilitrak type stuff, so it sucked nuts for donuts.
http://www.youtube.com/watch?v=G_KPz132TEg
Old 04-22-2008, 10:49 PM
ob_silverado's Avatar
Originally Posted by PSM
So you need to do both to get them both to shut off?
You press and hold it first traction control will go off then the autotrak will go off. You will know this is happening caise on your DIC.
Old 04-22-2008, 10:51 PM
Check you should have it. But when you put it in 4wd it will turn stabilitrak off or traction control. I can't rember. I would have guessed you would have it.
Old 04-22-2008, 11:52 PM
rgvsierra's Avatar
put it in 4lo and they both turn off..
when i use 4hi, you still have to turn in off manually, it basically sucks when in the mud
Old 04-23-2008, 03:21 PM
Y2KLimited's Avatar
wasn't available on 07 2500 subs, not sure if that worked out to 2500 and heavier pickups as well.
of course now in 08 you get stabilitrak and a 6 speed auto instead of the 4l80...
thanks GM for making me happy for buying a first year of a model run .....I always was happier buying end of a body style
Old 04-24-2008, 09:20 PM
WFOsierra's Avatar
If i leave stabilitrac on, will it affect my 1/4 mile times?..?
Old 04-26-2008, 09:57 PM
Y2KLimited's Avatar
in a vette with wheel spin the traction control will pull back throttle on its own with the drive by wire crap. I'd assume with a truck if you spin the same thing could/would happen. obviously with more weight the odds are less likely, but the sub was able to pull a smoke show on the stockers to the tune of a 3.1 60 ft in 2wd
BKnBLK05
12-28-2015 08:52 PM
Go5.3tt06
09-12-2015 09:29 AM
fillpot
07-26-2015 07:21 PM
lxcoupe
07-21-2015 02:12 AM
GM-only
07-19-2015 10:48 PM
Quick Reply: guys that have stabilitrak
