Have a problem with ABS
Old 01-12-2011 | 12:12 AM
nicky g's Avatar
Default Have a problem with ABS
Well here is the story on my abs light that keeps turning on when i launch my truck sometimes and it really bothering me. Would really like some answers on why it keeps coming on. I just installed a Procharger on my truck and i have a thunder racing custom cam kit with double springs and hardended pushrods and arp head studs, upgraded head gaskets and a yank 3000 stall. Just installed some tr6 spark plugs and taylor 10.4 spark plug wires. Still havent tuned the truck for the procharger but even before i had the procharger the abs light would flash and stay on for a while. Its really getting annoying and would like to see what you all thought of the problem. If anyone can let me know whats up just post and i will see.
Old 01-12-2011 | 07:04 AM
Ieatpeople's Avatar
how many miles on your truck?
maybe a wheelspeed sensor going bad? most abs problems i've seen have been sensor related...
Old 01-12-2011 | 08:13 AM
iamkeniff's Avatar
yeah that or "brake dust" on the sensor...
Old 01-12-2011 | 08:47 AM
nicky g's Avatar
my truck has 27xxx miles on it
yeah but im gonna have to find which one it is so i can fix it but it never did this back in the day when it was stock
Old 01-12-2011 | 02:11 PM
iamkeniff's Avatar
melted a wire on the harness by the frame/exhaust/brake booster?
over time the sensor will get brake dust on it no matter the mileage. you didnt change gears did you?
Old 01-13-2011 | 11:28 PM
nicky g's Avatar
No i didnt change my gears
But i will look under the truck so i can see if i have a melted wire somewhere
Old 06-23-2011 | 09:13 PM
KHester84's Avatar
Have you figured out this problem? I just installed a 3k stall and when I launch it hard, it'll spin the tires for a second and then the ABS light will stay on for a while. Doesn't seem to affect anything, although I haven't tried to slam on the brakes to see if ABS works.
Crazy.
Old 06-23-2011 | 09:51 PM
silverado1ss89's Avatar
Same here.. Just installed a circle d 3200 stall
And when I floor it... The abs light comes on too.. Hopefully a tune can take that away..
Old 06-23-2011 | 10:58 PM
2007chevy5.3l's Avatar
I used to have this problem, said service abs and stabilitrack system. When I swapped converters it hasnt came on since. Definatly a loose connection or sensor somewhere
Old 06-24-2011 | 01:21 AM
fast84's Avatar
Mine does it now after a hard launch with or without slicks??
Quick Reply: Have a problem with ABS
