having trouble with gmt 900 rcsb
I been having a problem with this truck for a few months now.
This what happens i be driving.. And out of nowhere my truck like flashes try to cut off... The whole gauges go on and off and it seem like if i turn it on again has all the lights on (check engine brake abs etc) plus the radio cuts off and the outer lights ... While drving... Took it to a shop specialize in mercedes.... Bmw etc electric work... He kind of fix it and he says its the fuse box thats mess up... Would anything know a place i can get it cheap or any suggestions.... Thanks
Well I haven't done any electronic mods... Just engine mods... And this problem sucks... Yeah I was thinking of burning it... And get a gto or sti....
Well for sure its the fuse box .... i went to the theater yesterday i came out and everything was dead(like it didnt have a battery).. i took off the fuse box and put it back and bam it work.. i went to work today and came back home(i dogged the **** of the truck) and everything work fine... and its not the superchiped because i took it off before and it still did the same problem.. also cut the mirror turn signal cable and still did the same problem...but for now its working fine.... i got a video in my iphone but i dont know how to uploaded... so ya can see and hear the problem
So i got this from chevrolet forum.. and it worked super happy
I currently have this problem in my 2008 Silverado.... have owned it less than a week with only 19000 miles on it. The door locks go wild locking and unlocking, guages fluctuate, compass display in mirror flashes illegible digits, strange stuff! I had it at the dealer today and they went through the mega fuse / connections (see TSB below). Everything seemed fine then the ghost returned later this evening. Clock reset and guages dropped momentarily.
Did you get a fix for yours?
Here is the tsb that I found online.
#PIT4816: Multiple Electrical Concerns With DTC C0900 - keywords battery c/k cable clock crank cycle door dimming flicker gage gauge gmc hvac inop inoperative instrument ipc lock no panel power radio stall - (Feb 27, 2009)
Subject: Multiple Electrical Concerns With DTC C0900
Models: 2007 -2009 Cadillac Escalade, ESV, EXT
2007-2009 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2009 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
(Equipped with Gasoline Engines)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customer may experience one or all of the following concerns.
1) Intermittent No Crank or No Vehicle Power ( The customer may get the impression that the vehicle actually has a dead battery )
2) Volt gauge fluctuates, and seems to decrease when a high load accessory is turned on ie.. headlamps, wipers
3) IPC backlighting flickers or IPC goes blank
4) Diagnostic Code: B1325 set in several modules followed with a Dtc: C0900 set in the EBCM.
5) Radio clock resets
6) Intermittent Stall
7) Hvac temperature actuator defaults to hot
8) Door locks cycle
Recommendation/Instructions:
If you experience one or all of the following concerns and a cause for the concern can't be identified, please check the following items:
1) Remove the 175 amp Mega fuse and inspect for arcing, if any type of arcing is found replace the effected components.
2) When re-installing the 175 amp Mega fuse, torque fasteners that attach the mega fuse to the positive cables to specification in SI.
3) Check the voltage drop reading on the positive and negative battery cables. The voltage drop should be performed with the fuel injectors disabled and while cranking the engine. The voltage drop should not exceed 200 mV. If the voltage drop is above 200 mV, replaced the effected cable.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Condition/Concern:
8) Door locks cycle
Yup it was that mega 175 amp fuse... i cleaned it and put it back together... haven't had no problem since.. knock on wood...
so heres the website i got it from... hope no one gets this problem it freaking suks...
http://www.chevroletforum.com/forum/...d.php?p=157590
