Header Leak Help
for the life of me i can not get my headers stay sealed up, every month or so - depending on how its driven i need to re tighten my headers bolts. if i rug on it hard right away they will leak instantly . I've tried the header gaskets that came with the headers, Malhe MLS factory style replacement and now have a mr gaskets crush style reusable one - 7406G if interested. ive tried OEM replacement bolts - no lock tight on them - multi sets of header bolts from summit and no change. they leak by the head, make that horrible ticking noise and the cab fills with exhaust and stinks.
what am I missing? I have never ever had this issue on anything else
next step I'm thinking is new GM gaskets and GM bolts with the dam locker on them. I'm just worried they are going to break like they do on stock manifolds.
Truck Info
07 yukon, 6.2, 1 7/8 headers, Y pipe is V banded with flex pipe to factory muffler, has a big chunky cam
Truck Info
strutaeng (11-29-2022)
few questions
stage 8 as in these guys?
https://www.stage8.com/gm-performanc...der-bolt-kits/
for the ARP are the bolts or studs?
no Loctite on any of them?
torqued to gm spec?
torqued to gm spec?
went thru this recently. the paper gaskets leak and was easy to spot when you remove em you can see the carbon plus it sound terrible. switched to GM OEM gaskets and that fixed it for me.
just used the upgraded arp ten point bolts from speed eng and the thin clamps on the piping. once they heat up they seal nicely.
