Heat and air problem
Old 03-07-2011 | 09:41 AM
6.2whitkon's Avatar
Registered User
Default Heat and air problem
Neither the front heat,air, or defrost is working. All the rear ac and heat work fine. The temp and fan gauge in the ac cluster shows that its working but nothing is coming out the vents. This happend all of a sudden, everything was working fine. This is in a 07 yukon denali.
Old 03-07-2011 | 10:47 AM
BrutalSierra's Avatar
Did you check all the fuses? Sounds dumb but you'd be surprised how often fuses cause problems.
Old 03-07-2011 | 01:47 PM
6.2whitkon's Avatar
Registered User
Yeah, I checked the fuses. I'm gonna check the relays this evening. Just wondering if this has happened to anyone else.
Old 03-11-2011 | 09:40 PM
Mrgoodwrench3's Avatar
Does the front blower motor come on? If not possible causes are a fuse, blower module or faulty motor.
ullose272
08-05-2016 02:05 PM
GMCtrk
12-18-2015 04:47 PM
wrb002
08-25-2015 03:56 PM
Jake99
08-08-2015 07:56 AM
Quick Reply: Heat and air problem
