Hellwig NNBS 7685 front sway bar and 7799 kit
Old 10-20-2012, 10:52 PM
JCunningham's Avatar
Default Hellwig NNBS 7685 front sway bar and 7799 kit
anyone install a Hellwig 7685 front sway bar in a 07-12 4x4. Would have been nice if Hellwig or Summit told me it required the 7799 spacer kit to install in 6 speed trucks. No one has one and summit list it as it will not be shipped until 11-5. WTF. I wanted to install my lowering kit and front and rear swaybars on the 24th.
Has anyone used this 7799 kit? What is it and could I make one? Im FU%KED with my supercharger and now with my swaybars.
Old 10-21-2012, 05:54 AM
07vmax1500's Avatar
What's so special about that bar that you need a spacer for?i get that it's bigger in diameter where's this spacer supposed to go? I've never delt with lowering stuff but I have replaced a bunch of sway bars before and don't see why a spacer would be needed. Have you takin the bar and held it in place under the truck to compare to the stock bar to the new 1?
Old 10-21-2012, 12:10 PM
Piss Pumps for Sale
Chevy Cowboy's Avatar
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
Im not sure about the early nnbs, but the late nnbs the sway bar actually runs right under the 6 speed transmission instead of up towards the front bumper. So im guessing the swap bar is much larger in diameter then the stock one, and requires a spacer to space the bar away from the frame, keeping it from rubbing the transmission
Old 10-21-2012, 01:00 PM
it needs the kit because of the 6 speed so ya id assume it is just a couple of blocks. if some one has used them maby they could tell me how thick they are so i could make my own.
Old 10-21-2012, 06:30 PM
splinter's Avatar
Aforementioned bar and spacer.
How close is your OE bar to the gearbox?
Old 10-21-2012, 10:14 PM
thats all it is is 2 pieces each side of sheet metal? what is that 1/4" the factory bar is 1 1/2 - 2" behind the tranny pan. ill just make the kit then
Old 10-21-2012, 11:47 PM
Old 10-22-2012, 08:16 AM
splinter's Avatar
^ Your blueprint looks perfect! Note there are two ~3/16” spacers on each side (~3/8” total).
They were “on backorder” from my retailer last year too, although a call to the friendly lady at Hellwig’s HQ prompted overnight delivery. ymmv
Didn’t really see any areas of potential bar-to-driveline interference at static 2WD/5.3/ECSB ride height, but installed ‘em anyway.
Old 10-22-2012, 09:37 AM
ok thanks
Old 10-22-2012, 09:41 AM
splinter's Avatar
:cheers:
Quick Reply: Hellwig NNBS 7685 front sway bar and 7799 kit
