Help guys 07 vortec max 2300 maggie wnt tune for 80lb inject factory ecm limits it 63
Old 08-06-2012, 06:31 PM
silverstreak07's Avatar
Default Help guys 07 vortec max 2300 maggie wnt tune for 80lb inject factory ecm limits it 63
I had som injectors resized from FIC there 80lb injectors!well we were gona put in my truck but for a 07 MAX the ECM says 63lb injectors are the biggest..my friend checked other trucks he tuned like a 08 5.3 they say 120 injectors.so when he tried to put in the data it didnt work..WHAT DO U GUYS DO..we tried a ECM from a 09 siverado put the data in it the truck didnt take and ran shitty..BASICALLY WITHOUT A BIG HASSLE can a guy change that in my ECM TO TAKE A BIGGER INJECTOR than 63pounders..
Old 08-06-2012, 07:50 PM
scooter k's Avatar
Don't know how they do it but I'm running 210lb injectors
Old 08-06-2012, 07:55 PM
Resident Retard
BlackGMC's Avatar
Are you sure you had the unit set up correctly?
Old 08-06-2012, 09:03 PM
Boober's Avatar
You will need to scale your IFR. the limit for newer ECM's is 63.5 lb/hr
Generally speaking, (I only know my own ECM limits) multiply injector flow rate by .5 and stoich fuel ratio by 2.
A good tuner will know exactly what to do. Go to hptuners.com or whatever website EFiLive users gather in. There are 100's of topics covering this (gets a little intimidating).
Old 08-07-2012, 11:10 PM
THANKS GUYS well we got the 80lb injectors tuned today runs good!!I have been wanting to run E85 so my tuner switched the tables and we ran filled it up w e85 runs good but running to lean as rpms come up higher than 4500 the fuel pump is dropping to 30psi so thats why we must not be able to richen it up!!!!IS THERE ANY cheaper way to get more fuel pump,pressure etc.WHOS RUNNING E85 IS IT WORTH IT IM NEW TO THIS BUT HAVE HAVE A MAGGIE WAS TOLD SHOULD GAIN ALOT!!!what are your recomendations without spending crazy amounts of money!!!
Old 08-08-2012, 03:01 AM
SLCviaAK's Avatar
Please stop yelling.
Old 08-08-2012, 08:28 AM
Boober's Avatar
Uhhh, get a higher flow fuel pump....
Seriously, your stock pump (it's still stock right?) is probably not capable of delivering enough regular fuel to those 80's, let alone trying to do it with E85.
You might consider a stock, flex fuel, pump from an L9H truck. I don't know the flow rate but from what i understand that they are pretty good. If that's not enough, go aftermarket. It's the only choice you have really.
Good luck!
Old 08-08-2012, 08:52 AM
Slow08's Avatar
Try finding a fuel pump that works on pulse and not a constant 12V with the FPCM it isnt available without going to a return style system
Old 08-08-2012, 09:07 AM
nonnieselman's Avatar
Can you just not take the FPCM out and run a Fuel pump with a regulator at the tank?
Old 08-08-2012, 09:41 AM
does anyone know if a flex fuel pump is better or have used one..Whats the pump bigger.I have the stock fuel pump seemed to be good with the regular gas dropped sum but with the e85 it dropped alot!!!
Quick Reply: Help guys 07 vortec max 2300 maggie wnt tune for 80lb inject factory ecm limits it 63
