hey 6.2 owners
#33
1. deleted via tuning if a NON vvt aftermarket cam is installed, which requires an ls2 cam gear, timing cover and a reg ls based style cam.. (ex. 3 bolt cam).. and something that i might no remember right now
2. or if u install a vvt cam along with the installation of cam phaser kit to limit degrees of timing, comp and mast both have a few of those.. and those do require some vvt tweeken...
wheatly or others can chime in and better explain.. still trying to figure it out myself lol
#34
VVT tuning turns in superb results but for each change in cam timing it also messes with ign timing and fuel trims so it adds a whole new dimension of complexity to tuning. Heres a quote from Patrick G over at Ls1tech
EFI Live does a great job with VVT. HP Tuners also can adjust VVT although I have not seen that it can adjust some of the key VVT timing tables. Perhaps they now have it covered with a newer beta version.
We picked up around 40 lb ft of torque in the mid-range by playing with cam phasing on the Denali. We also gained around 20 rwhp at 6000 rpm by retarding the cam more than stock.
#36
Yeah VVT tuning is still pretty new to the GM scene but as it unfolds VVT is a HUGE part of the future for GM and the aftermarket. Theres really no arguing against its benefits really it gives you more power under the curve than a static cam ever could. The only real issue we have right now is PTV clearance as this is the limiting factor.
Im build a 6.2L t56 87 Camaro swap retaining VVT now. 222/230 .600 cam LT's etc etc. Should cook along quite nicely once its all said and done. Especially considering I'll be at 3300lbs ( already had an LS1 in there and weighed it so thats how I know 3321 or sumthin )
MA$TER_E
09-09-2015 03:14 PM
PDPERFORMANCE
09-08-2015 11:01 AM
