how low can i go with a 4wd NNBS?
he has drop spindles in the front with belltech drop struts and in the back her has a djm flip kit and a djm sway bar his all the way down at 4/7 i i have the same drop same set up but only went down to 3/5 all works amazing drives better then stock
I'm 5/8 with 4wd...here is my parts list...
Front:
-lowering struts #25003 (205$)*
-2" drop spindle set #2509 (275$)*
-pro coil spring set #12463 (200$)*
-front anti-swaybar #5407 (190$)*
-alignment kit #4957 (80$)*
Rear:
-5"/6" flip kit #6521 (290$)*
-DJM 2" lifting shackles (85$)*
-adjustable 1" drop block set (50$)*
-performance shocks #2210 (120$)*
-bumpstops (30$)*
-custom 1/2" U-Bolts (80$)*
-6° pinion shims (40$)*
Front:
Rear:
-bumpstops (30$)*
How is that rear swaybar working for ya? I've been looking into getting one for the rear to help keep the tires from catching the fender well...
works grate but id recommend the hellwig sway bar not the djm bec the hellweg has adjustable end links witch is perfect for mounting around exhaust and any other part under there my djm hit my exhaust at the moment i ordered the hellwig end links and im gonna switch them out... but deff worth the buy the trucks drives like a champ.
-Front Ground Force GM 07-10 Drop Spindle Part# 6010 (2" drop)
-Belltech lifting & lowering struts part# 25003 (adjustable anywhere between 2" lift to 2" drop)
-Rear DJM Flip Kit Part# RK2507-5 (anywhere from 4" drop to 5" drop)
-Bell Tech Street Performance Shock Part# 2210FF (Not adjustable but you need a shorten shock with flip kit)
-DJM rear sway bar ASB2599R (recommend the Hellwig 7800 Rear Adjustable Sway Barbar though because hellwig has adjustable end links djm das not)
with all these parts installed you can have a 2/4 3/4 4/4 2/5 3/5 4/5 drop
with these part any hight you want is possible everything is ajustable
