I want hi quality quiet gears. Who makes them
Old 08-08-2012, 07:48 AM
Originally Posted by JCunningham
...I'm reading on here they are not really needed with a 6speed but I'm not doing a cam or headers because I have a warranty and don't want to void it buy doing something permanent to the motor. I think gears wont void the warranty other then on the axles. I have a tuner, 90mm TB, a MIT and will do a Borla Touring cat back.
Technically, a tuner voids the warranty.
I read the g80 mite go boom. This is a new truck and I dont beat on it. should I put a differant locker in it. My tires mite spin sometimes but my locker is for winter traction not smoke shows. what should i put in?
The G80 in the 9.5" 14 bolt doesn't go boom. It's very stout. It happens in the 8.5" 10 bolts occasionally though.
If I were changing gears, I'd just buy Motives for about $200. I've used them many times in the past, with good luck. The noise usually comes from improper setup. The pinion depth has to be set perfectly, or it will whine.
Old 08-08-2012, 09:22 AM
LaBlackIce's Avatar
I was getting 19 to 21you on the highway and 12 in the city playing around
Old 08-08-2012, 09:49 AM
nonnieselman's Avatar
AAM is OEM so thats the route id go.. i have 260,000 miles on mine and they are still quiet
Old 08-08-2012, 02:23 PM
Man Motor club
rjwz28's Avatar
OEM for the win. Go AAM.
Also, ANY dealer can tell if you currently have an aftermarket tune. You currently have an aftermarket tune (a shitty canned tune is still a tune) so they will void your powertrain warranty if they find out (which they will if they hook up a Tech2). The debate is whether they can see whether there was a tune after the factory tune has been reloaded; all the evidence I have seen says they can't on our trucks, but they will see flash history on the next generation.
Old 08-08-2012, 02:24 PM
Man Motor club
rjwz28's Avatar
I would leave the G80 alone
Old 08-08-2012, 03:26 PM
LaBlackIce's Avatar
probably i will go back to 373's or Im going to buy another truck for my long trips.
Old 08-08-2012, 04:10 PM
11 Second Club
Phantom's Avatar
I use the value gears from Rons Machine Service. I have 4.56's. They are quiet as can be. My break in procedure consisted of driving off the lift, pulling out into the street, doing a burnout and making a pass I've made many many passes and they're still quiet as can be. Setup definitely plays a big part in noise reduction
Old 08-08-2012, 04:35 PM
Man Motor club
rjwz28's Avatar
That's awesome
Old 08-08-2012, 04:37 PM
Man Motor club
rjwz28's Avatar
I wish I could have ordered 4.10s in the first place
Old 08-08-2012, 05:31 PM
youngone2011's Avatar
Oem x2
Quick Reply: I want hi quality quiet gears. Who makes them
