Ignition coil harness on correct?
Old 05-11-2016 | 08:17 PM
TAPyvehc93's Avatar
Default Ignition coil harness on correct?
How can I tell if I have my ignition coil harness plugged into the right cylinders? I just want to make sure that I don't have it flipped backwards. Other than starting it up and seeing if it backfires lol
Old 05-16-2016 | 11:16 PM
07NBSChevy's Avatar
They are in sequence on the harness........unless the loom is screwed up than its pretty self explanatory. They are spread out every 3 inches or so. Just plug them in to their corresponding location relative to the harness. Did you remove the loom from the hard plastic tray they are in?
Old 05-17-2016 | 01:06 AM
Wolftrk99's Avatar
If you want to get technical about it, a wiring diagram would tell you by wire color what connector goes to which coil....
99ta
05-12-2016 11:03 PM
BlueTexan24
31
05-09-2016 07:48 PM
Bluecollar Hotrods
04-24-2016 08:17 AM
05GMC4.8
04-20-2016 10:18 AM
fullboardmax
04-14-2016 12:34 PM
Quick Reply: Ignition coil harness on correct?
