Independent Rear Suspension
Old 02-17-2012 | 10:25 AM
two-piece's Avatar
Default Independent Rear Suspension
Ok guys im setting up a IRS. Im using a center carrier from a Ford Expedition (9.75") and will custom build the a arms and spindles. I will have a set of axles made to a custom size for my narrowed track width because I'm bagging the truck at the same time. I need help with my hub choices. I'm want to try and stay GM for bolt pattern and ABS comparability. My first thought is 4wd hubs, but will those hold up to full time use? Thanks for the help.
Old 02-17-2012 | 10:52 AM
89LS1FOXER's Avatar
4WD front hubs should work great!
Old 02-17-2012 | 11:26 AM
nonnieselman's Avatar
Just a thought, could you get the ford hubs redrilled for GM bolt pattern?
But yea, the GM front hubs should be fine. Or go for 3/4 ton hubs and get them redrilled for 6 5.5?
Ive run out of ideas now.
Old 02-17-2012 | 01:57 PM
62nalide's Avatar
Don't the make a bolt on kit for GM trucks for IRS? I saw it in a mag before
Corvette454l88
09-01-2016 01:24 AM
chopperloco
07-10-2016 10:45 PM
black03rcsb
09-01-2015 10:17 AM
DarkhorSe_SS
08-20-2015 08:58 AM
Ketis
07-23-2015 12:37 PM
Quick Reply: Independent Rear Suspension
