Input on swapping to a little bigger cam!
Old 09-21-2011 | 06:02 PM
HAMMER!'s Avatar
But you and cheverlade have 6 speeds! The fall off with the 4speed sux cause I have to spin the cam past peak #'s so the shift drop isn't so bad(down to 3900rpm) until I got shift points moved to 6700 then it drops to 4250rpm BUT I've lost 30-35 rwhp from 6250rpm to 6700! No doubt this cam would be better suited in a 6 speed truck but even still stop pulling so early sux! All that being said the cam is a beast from 3700-6250rpm some people even thought I was spraying the truck cause it hit so hard( which I like) but wish it would make power till 6800 or so!!
Old 09-21-2011 | 06:11 PM
HAMMER!'s Avatar
I think the big dur. Splits on l92 heads make alot of sence due to port volume and valve size. I've talked to Roger @ Vinci and he spec'd me a cam that I like and made alot of sence and will pull to the moon! I think with this cam and 6 speed swap to come will make up on bottom end! Thanx for all the input guys!! I will let y'all know what I do and the results! Might even do a thread on it
iregret
07-27-2015 10:32 PM
projectnightcrawler
07-19-2015 11:30 PM
06 4.8
07-15-2015 07:17 PM
4B11T
07-13-2015 03:48 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: Input on swapping to a little bigger cam!
