Looking to swap powertrains in my 2010 Avalanche
Old 09-04-2024, 10:25 PM
Registered User
Dan Solo's Avatar
Default Looking to swap powertrains in my 2010 Avalanche
Let's rip the bandaid off; the Avalanche ain't a real truck yadda yadda. Having gotten that outta the way, I'm looking to breathe new life into my tired *** truck.
Initially, I was going to do an interior update; focusing on modernizing the infotainment system, which then became my wanting to eliminate my column shifter in favor of a console shifter to accommodate a sizable floating screen head unit.
I bought a used 2015 Camaro AT gear shifter, and in doing my research on how to make it work with the 5.3L ECM and 6L80 TCM I found out that the shifter won't work.
Then I looked into swapping the 6L80 for the 8L90 which brought me here, so I figured this would be a good place to get some advice on what people have done to update their GMT-900 powertrains.
Some engine/transmission combos I'm considering are 6.xL/8L90, TT3.6/8L90 for performance and fuel efficiency improvements, with newer 5.3L/8L90 as a last resort because I don't feel that they offer enough additional HP to justify the money spent.
So, what powertrain conversions have you fine folks done on your GMT-900s?
Old 09-05-2024, 08:54 AM
shakenfake's Avatar
Received 1,278 Likes on 975 Posts
Fortunately we cater to all full size vehicles. Hell even Trailblazers
Okay I would NEVER EVER EVER swap a 6 speed for an 8 speed. The 10 speeds look really nice but I probably would keep the 6 speed for a while longer yet. **** the 8 speeds. They are garbage transmissions. I do not know if you could get a TT3.6 to work however I honestly don't see why not. I would recommend just throwing in a 6.0 or a 6.2 if you really want a new engine or going ahead and supercharging or turbocharging what you have.
The following 3 users liked this post by shakenfake:
68Formula (09-05-2024), smokinlmm (09-05-2024), strutaeng (09-05-2024)
Old Today, 04:39 AM
Drspencer's Avatar
Where you're probably hurting is the 3.23 or 3.42 axle that thing has. That will take some of the pressure off the trans when trying to move that 5500lb beast. I loved my avalanche but no 6.0/6.2 option and the Escalade EXT only came with a 5.3 in 2WD form. Agree with the above, though. Asking for trouble on the 8 speed and you can make a robust 6 speed with what you would spend trying to make the 10 speed work. Also, yes, a drop in 6.0 or 6.2 would get the truck back on the road sooner and reliable.
Old Today, 11:00 AM
smokinlmm's Avatar
I agree about the 6l80, they can be built to last now. The 8 speed detonates at factory power levels. If you want a bad *** trans factory buy the ford 10 speed.
firebladeJJ
317
09-16-2024 01:23 PM
cmarshall48
01-14-2023 08:37 AM
blownescalade62
12-11-2016 03:36 PM
cttandy
12-31-2010 07:51 PM
ap2002
07-09-2010 10:54 PM
Quick Reply: Looking to swap powertrains in my 2010 Avalanche
