Lost Communication with Several Modules
#31
U0100- Lost Communication with ECM/PCM A
U0101- Lost Communication with TCM
U0102- Lost Communication with Transfer Case Control Module.
U0121- Lost Communication with Electronic Brake Control Module.
U0140- Lost Communication with Body Control Module
And OCCASIONALLY a U0155 and U1814. But they seem to go away.
It also throws a CXXXX code. :/
#35
Find a used bcm for your truck even if it's not uplevel. Get it as cheap as possible to use it for diagnostic purposes only. Stick it in your truck and see if you can get the modules online correctly. Man if it was in my shop I could do a lot better for ya esp computer diagnostics are a PITA. Reading around it all data the modules are not seeing the correct wake and sleep cycles on the high speed buss. These cycles are directly controlled by the bcm. I really think the bcm turned turtle.
If you are in a real spot I can order a gm bcm for you and program it to your vin.
#36
Gray Ghost acting weird part 1 - YouTube
I have part 2 uploading right now. I'll get it up ASAP.
