Low, almost no backpressure
Old 07-10-2009 | 02:24 PM
BlueSS's Avatar
Originally Posted by Spoolin
I'm still not convinced that it's a myth.
X2. Thanks for all the replies guys. I know some 4.10 gears and a stall would help out a lot, but i know that the bottom end should be better than it is right now. 4.10's and a 3200 p.i are in the works but i don't want to do that till I get it running the way it's suppose run with the current mods.
Old 07-10-2009 | 04:24 PM
Occupational_Hazard's Avatar
Originally Posted by VMax
I agree with this man. Dragsters and Funny Cars dont have nothin but straight headers. The less resistance, the better. Ask any real racer.
so drive around town with no manifolds and/or headers bolted up. lol
Old 07-10-2009 | 05:54 PM
VMax's Avatar
lol. i pretty much do man. cut out is open everyday. When i put it in to get it inspected it is a terd. So i can prove that less restriction is the best method.
Old 07-10-2009 | 07:02 PM
iamkeniff's Avatar
i cant agree after my headers and driving 20 miles to have my my exhaust redone i got 11mpg at 70 mph and it was so loud i couldnt hear anything. the truck was so slow i almost got ran over by an electric wheelchair lmao jj but it was super slow vs how it is now
Old 07-10-2009 | 08:54 PM
fast84's Avatar
That's hilarious!!!!
Old 07-10-2009 | 09:14 PM
Spoolin's Avatar
GFYS and STFU
Some restriction is necessary but there's a limit to it ya'll. You can't just say more restriction the better and the less the better, it's a balance where some is needed but too much is obviously hurting.
Old 07-10-2009 | 09:31 PM
GMCtrk's Avatar
Explain this more as to WHY you think "backpressure" is necessary. More resistance to exhaust flow is more energy spent ejecting exhaust gas rather than spinning the crank...PERIOD. The reason we even want properly sized exhaust pipes instead of the biggest pipes possible is that increased gas velocity increases vacuum. And that vacuum helps evacuate the exhaust from the engine cylinder. Therefore, more of the energy from combustion goes towards spinning the crank. Have you ever looked at exhaust flow numbers on cylinder heads? Ever wonder why the numbers are higher when they put pipes on the exhaust ports?
Old 07-10-2009 | 09:58 PM
Spoolin's Avatar
GFYS and STFU
You should hang out on the LS1tech side more often, you'd like it more over there. (not a compliment)
My post was meant for those people suggesting running without headers or exhaust manifolds period.
Here you go so that you don't feel I'm proving you wrong!
"It may seem intuitive that bigger, more open exhaust would be the best for engine performance. Some believe that there is a proper amount of exhaust back-pressure for optimum performance. Both of these theories are wrong. There are a few key things that make exhaust flow different than other fluid flows. First of all, the exhaust is coming out in pulses. When each cylinder exhausts, a large surge of flow enters the exhaust system. Then it stops again until the next exhaust stroke. True, larger exhaust ports and tubes will flow better but flow is not the only thing to consider here. If you size the exhaust tubing properly, you can take advantage of the inertia of the exhaust pulses similar to what can be done on the intake side. When the cylinder exhausts, the pulse builds a pressure in the exhaust tube. Once the valve closes, this exhaust pulse is traveling down the tube with velocity. Because of this, a slight vacuum is created at the valve. This pressure-then-vacuum pulse will travel all the way through the exhaust system assuming the restriction is low and the tube diameter does not change much. The tubes for each cylinder to the collector are called primary tubes. These primary tubes can be sized, both diameter and length, to optimize the exhaust inertia while keeping minimum restriction. It is a trade-off and will only be optimum at a specific RPM and load. This is very similar to optimizing the intake system and the same key things apply. For low RPM performance, a small diameter, long tube will give the best port velocity, and exhaust inertia. For midrange performance, a shorter length, larger diameter runner is best. For very high RPM, a very short, large runner is needed because restriction is the biggest problem at high RPM.
By grouping primary exhaust tubes into a collector, the vacuum pulse from one cylinder can be used to create a vacuum on the other exhaust ports. This vacuum will cause the exhaust to begin flowing more quickly as the exhaust valve opens. The collector must be long enough and small enough to keep the inertia of the exhaust pulse optimized while keeping back-pressure low.
Back-pressure is something we are stuck with, not something we want. By optimizing the inertia affect, some back-pressure will be realized during the peak of the exhaust pressure pulse. It is not something you want but rather simple physics.
Once you get past the end of the collector, you want to release the exhaust with as little restriction as possible. The end of the exhaust header is not really the end of the collector. The collector area in the exhaust should usually be about 18" to 24". If you have 2 banks of cylinders with each bank having it’s own collector, you will also have alternating pulses from each bank. In order to reduce restriction, you should place a tube between the banks at the end of the collector area. This will allow pressure pulses to swap back and forth which will even them out and allow smoother flow through the rest of the exhaust system.
At very high RPM, the restriction becomes a much bigger problem. Because of this, attempts to utilize exhaust inertia are generally abandoned in favor of reducing restriction."
Old 07-10-2009 | 10:19 PM
GMCtrk's Avatar
[/SIZE]
Do you think I am a mind reader? If that's what you were talking about then try putting it in the post. I really not so sure why you got so bent out of shape over this.
Old 07-12-2009 | 09:40 AM
nighthawk08's Avatar
the new trucks are dogs off the line no matter what....until you stall them. a 3000 stall would make a HUGE difference in your 1/4 mile time.
Quick Reply: Low, almost no backpressure
