Low Oil Pressure Issue
It doesnt throw a code until i run the motor for about 30 min or so...ie. heating up and thinning out.
I know its not a bearing clearance issue due to the fact that I now have 10k miles on this newly built motor and I have been driving the **** out of it. I think it wouldve gave by now if that was the case.
I put a quart or 20w50 in it and it actually helped it a lil bit, maybe 4-5 psi
Cold start idle- 40 psi (normal right?)
30 min running warm idle-10 psi (low right?) It does jump up significantly when i rev it up.
put 10w 30 or 20w 50 whatever you feel like. i run 10w 30 and never had a issue with any truck. if it was the o ring you wouldnt have normal pressure on first crank up. also you dont have to have the cooler as a ton of trucks dont. did you swap your cooler plate back to one that doesnt have the oil ports?
IMPORTANT LS Gerotor Oil Pump Data - Corvette Forum
So do you think its safe to say my mechanic made a mistake by throwing a ported TSP LS6 oil pump on a VVT engine which required a bit more oil flow?
Noah Burns
09-07-2015 05:50 PM
superchomper2003
08-26-2015 09:39 AM
05GMC4.8
08-07-2015 09:55 PM
Ferocity02
07-17-2015 07:05 PM
