Lowering a 4x4 nnbs and warranty questions.
Old 12-22-2011 | 08:21 PM
On mine I had to move space the trans mount up and then space the trans off the mount to get the rear driveshaft angle correct. It had a horrible vibration due to pinion angle. Hence by moving the trans up it also effected the front drive shaft angle. It has a mile vibration at 70-75 when t-case is in auto only.
Old 12-23-2011 | 12:35 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Silly question, but why in the world would you need to use auto 4x4 at 70 mph in Texas??
I use it all the time here, but on snowy/icy roads.
Old 12-23-2011 | 02:29 PM
When it rains on the occasion that it does and I live down a nasty road but i'm not driving 70 down that road anyhow.
Also when out playing in the twisties the main reason I dropped it.
Old 12-23-2011 | 02:32 PM
I see. I get quite a bit more understeer(push) with my truck when I'm in 4x4 and driving hard in the twisties.
Old 12-23-2011 | 02:57 PM
Mine does pretty much the same thing but if you go in low on a corner and really dog it through the apex it sure is a blast to drive. I've got 17" michelins until they get low enough on tread to put the denali 20's on. But they stick and hold pretty damm good considered they were never meant to be used like that on a truck.
Old 12-23-2011 | 04:18 PM
Now, for drag racing you would go above 70 mph, what would be the lowest you could do then?
Old 12-23-2011 | 09:23 PM
I'm 3/5 and have launched in 4 hi. Vibration goes away at 97 but it's a barely noticeable vibration.
Old 12-23-2011 | 09:28 PM
The silver 2011 with the 5/7 should be making some passes in the spring. I think the track opens up around Mother's Day, but the schedule isn't posted yet.
Old 04-22-2012 | 06:47 AM
chanin6929's Avatar
Sorry to bump an old thread, but I'm at 5/8 with my ext cab 4x4...I get the vibration/rattle at anything over 60 when I release the gas pedal...tried shimming tranny and that moved the noise to 80+...tried 2degree pinion shim, no change...tried 4 degree pinion shim, no change...should I attempt a 6 degree? The noise is obviously coming from the back, it isn't CV's or differential...I did notice a little oily wetness on the rear end of the driveshaft...any solution??
Old 04-22-2012 | 02:53 PM
stg313's Avatar
I am running a 5/5 with no problems on my truck
Quick Reply: Lowering a 4x4 nnbs and warranty questions.
