McGaughys 3/5 drop kit
Old 09-13-2009 | 06:17 PM
fast84's Avatar
Default McGaughys 3/5 drop kit
Anyone done the 3/5 drop on a NNBS reg cab 2wd truck? If so how bout posting some pix? Done a search but won't show me what I want to see. If not McGaughys how bout pix of other brand 3/5 on nnbs reg cab???
Thanks, Jeremy
Old 09-14-2009 | 08:46 AM
a_guerrajr's Avatar
no pics, but there are some out there.
Here are some options..
Front:
2" Spindles Belltech or Ground Force
1" or 2" Belltech Struts, you can set the desired drop
1" or 2" coils
Rear:
Ground Force Leafsprings w/ no lift block
MCG flip kit with hangers
Old 09-14-2009 | 11:37 AM
ls3s10's Avatar
you can lower it if you want to buy balljoints every 25k i hate my kit rides like crap. i called belltech said mcgaughys is german for no alignment . you will never get it in alignment and it eats tires i have 4 -5 kit
Old 09-14-2009 | 07:48 PM
fast84's Avatar
HA HA HA!!!! That's hilarious. Not that it rides like crap but the german crack!!!! Thanks for the heads up.
Old 09-15-2009 | 10:21 AM
a_guerrajr's Avatar
i'd go ground force spindles, worth the extra money. especially when you start thinking about ball joint, angles, and tires.
Old 09-15-2009 | 03:30 PM
gdev_'s Avatar
I swapped the McGaughys stuff for Belltech when my front (4/7") settled the first time. Replaced stock strut/MCG spring for a BT adjustable strut/BT spring, and the adjustable alignment cams. Guess what? Same problem, less than 5k miles later.
Got any better (bigger) pics of your truck?
Old 09-17-2009 | 03:02 PM
stephenok711's Avatar
Sorry for bad pictures.
http://img245.imageshack.us/img245/6...q55se99d20.jpg
http://img196.imageshack.us/img196/7...pa5sa99d58.jpg
Old 09-17-2009 | 09:45 PM
fast84's Avatar
Thanks for the pix man!!!!
GXPJAY
02-13-2022 09:15 AM
GMCSIERRA5.3
08-07-2015 02:50 AM
So.cal Wrk Sled
07-26-2015 01:10 AM
Ketis
07-23-2015 01:37 PM
