MUFFLER help me choose
#21
To the OP, check out Magnaflow website and you will see a large assortment.
If you want to be able to hear your truck go with a large case 14" and if you want to be just a little louder than stock go with a 22" Magnaflow.
You can search on here and you tube for plenty of sound clips wiuth people running any where from stock motors, cats and a muffler to all out modded motors, no cats and mufflers.
Best of luck, but all my money is on Magnaflow.
#23
i realized none of the guys on this forum install corsa well maybe just a few.. maybe cause it costs alot , u guys wont believe how much corsa catbacks cost over here damn.. the cheapest u could find is around 1700$~
i would recommend a 20inch+ magnaflow maybe a 22 imo it would sound amazing with headers or without but thats just me
#25
Got the 14909 magnaflow finished up tonight and left the stock resonator in place. Sounds beefier at idle, can hear it while accelerating once it hit od from 65-90 can barely tell it's a bit louder than stock. At WOT definitely has a very nice tone and sound to it.
I am contemplating experimenting with removing the resonator to see what it will do but right now I have zero drone. Does anyone have this muffler with full cats intact and the resonator removed.
#27
Im scared to play with it too much. My other truck had a cammed 6.0 and with the muffler alone it would rattle change in the ashtray and cupholder while driving. I had to go back and do a magnaflow resonator behind it to shut it up enough to make it tolerable to drive.
#28
#29
#30
I put the offset at the front and center at the rear. Only had to add about six inches of pipe. I pulled the tailpipe out and tweaked it over a bit in the pipe bender to square the tip up back underneath the rear bumper to compensate for moving the tail pipe over at the muffler end. I finished the tailpipe with a gm performance parts stock tip. I'll try and get a idle vid up late sunday or monday. Took about an hour and a half start to finish
