MUFFLER help me choose
Old 12-24-2010, 08:54 AM
  #41
Originally Posted by Tex20
I've got a regular flow 40 on my 08 4.8 with dumbs, stock piping with a muffler and sounds pretty damn good to me. Isn't crazy at wot either, kinda quiets down and you mostly hear the motor. Between 1500 and 2000rpm is probably its loudest. But nonetheless, sounds really nice.
That "motor sound" you (and others hear) at 1500-2000 is drone. Does it make your ears ring a tiny bit? Or other vibrations in the truck? (rattling coins in cupholder) make your ears feel like they need to pop?
Put a corsa on and that'll go away. You'll hear the sound move from in the cab, to where it exits.
Old 12-24-2010, 09:36 AM
  #42
Dont get me wrong it sounds reallly nice right now. You can definitely tell it's not stock. I want just a few more db at idle and cruising out of it than what I have now. But I'm not swapping mufflers again if the cat doesn't do it then at that point it is what it is.
Old 12-24-2010, 10:22 AM
  #43
Red04Silverado's Avatar
Originally Posted by gonzo 6.0
how about a dynomax VT?
Thats the muffler Ill be going with for my DD.
Old 01-03-2011, 09:41 PM
  #44
fredkj3's Avatar
put on the 14909, 22" magnaflow.. and i dumped it right after... i think it sounds great.. its a little quiet.. no drone.... it has a great low rpm throaty sound.. and at higher RPMS it sounds good.. but it is DEF not loud....
Old 01-04-2011, 09:59 PM
  #45
I didn't gut the 3rd cat on mine like I was going to do.
I cut it out and welded v-band flanges on both ends and then took some stainless 3.5 pipe and welded v-band clamps on it also. I put the straight pipe in and man oh man do she sound nice now. Really nice burble at idle, can def tell it has pipes while accelerating moderately and she sounds like a b-29 when at WOT. At the same time should the need ever arise in the future I can pop the after cat back in and shes a legal beagle again.
Old 01-04-2011, 10:02 PM
  #46
gonzo 6.2's Avatar
any chance you could post a pic of the 3rd cat?
Old 01-04-2011, 10:23 PM
  #47
fredkj3's Avatar
where is this THIRD cat??? i have the manifolds.... 2 cats in the Y pipe... then it comes together to the 3.5" cat back where there is a vibration absorber... then a straight pipe to the muffler... then it had a resonator after the axle....
i cut the old muffler and everything behind it... used the factory tail pipe to make a turndown and welded that to the muffler... welded a hanger to the tailpipe and then use a clamp to clamp the front of the muffler
Old 01-06-2011, 11:12 PM
  #48
Banned
pl4yboy's Avatar
There isn't a third cat on mine. 2 in the Y, Muffler, resonator. That's it.
Old 01-07-2011, 10:14 PM
  #49
Mine is an 11 model. It is about three inches infront of the flange for the catback.
'02SOMz28
11-02-2015 05:47 PM
03sierraslt
14
10-09-2015 05:53 AM
Rockrz
09-29-2015 09:07 AM
sTNT971
09-26-2015 04:22 PM
Quick Reply: MUFFLER help me choose
