MUFFLER help me choose
#41
I've got a regular flow 40 on my 08 4.8 with dumbs, stock piping with a muffler and sounds pretty damn good to me. Isn't crazy at wot either, kinda quiets down and you mostly hear the motor. Between 1500 and 2000rpm is probably its loudest. But nonetheless, sounds really nice.
Put a corsa on and that'll go away. You'll hear the sound move from in the cab, to where it exits.
#44
put on the 14909, 22" magnaflow.. and i dumped it right after... i think it sounds great.. its a little quiet.. no drone.... it has a great low rpm throaty sound.. and at higher RPMS it sounds good.. but it is DEF not loud....
#45
I didn't gut the 3rd cat on mine like I was going to do.
I cut it out and welded v-band flanges on both ends and then took some stainless 3.5 pipe and welded v-band clamps on it also. I put the straight pipe in and man oh man do she sound nice now. Really nice burble at idle, can def tell it has pipes while accelerating moderately and she sounds like a b-29 when at WOT. At the same time should the need ever arise in the future I can pop the after cat back in and shes a legal beagle again.
#47
where is this THIRD cat??? i have the manifolds.... 2 cats in the Y pipe... then it comes together to the 3.5" cat back where there is a vibration absorber... then a straight pipe to the muffler... then it had a resonator after the axle....
i cut the old muffler and everything behind it... used the factory tail pipe to make a turndown and welded that to the muffler... welded a hanger to the tailpipe and then use a clamp to clamp the front of the muffler
