Muffler swap gone complicated
I was just looking for something a little more pleasing to the ears so I thought I'd do a simple muffler swap with a Borla XR-1 or AT3535. Turns out my local muffler shop is not able to bend anything over 3".... yeah i know .
Has anyone went through this and can provide input? ...or am I the only one?
I don't want a chambered offset muffler and I'm not a magnaflow fan. What about some of that stainless steel "flex pipe"?
Thanks.
Thanks.
put a turn down off the muffler???
Or order a few 3.5" U bends & have your exhaust guy make a tail pipe... or they can order premade tail pipes that they may be able to modify to fit in 3.5" or 4"
i had the same problem, then i finally found a muffler shop with pre bent 45* 3-1/2" pipe. they cut up 2 of them to install my borla xr1
11 Second Truck Club
Me too. When I went to install my magnaflow center/offset it wouldn't line up because stock is offset/offset on the 6.2. Ordered a stainless 3.5" 45* from summit and my muffler guy was able to make it work. This was needed to keep the factory resonator and tailpipe.
Thanks guys.
I've thought about dumping it after the muffler but had that before and it drone'd bad plus i want to keep the signature 6.2 tailpipe.
I was hoping some of you had ordered some pre-bends and it worked, which seems to be the case. Can I a few more suggestion on which pieces and places to order from? I appreciate the ones above; just looking to get more options.
Suburban2500
07-19-2015 04:50 PM
Suburban2500
07-13-2015 09:57 AM
