My 08 Sierra final build pics
#28
If you have 4L60 its piece of cake. Trailblazer shifter, shift cable, and the bracket on the trans and its done. Then the custom work building or fitting it into a console. Remove the stock shifter bs off steering column. You are on your own to cover the hole in the column plastics as gm never made these trucks with a manual tranny.
But this column is used in several other gm platforms including few cars etc and may be able to do some research to find the column halves from one of those cars with a console mounted shifter.
#30
EDIT**
OK... I found this... GM P/N 19177758 .. Its the top cover for the column out of a 2008/2009 H2 which has the console shifter...
