Need a better 60ft!
Old 12-05-2010 | 01:55 PM
supercharged680's Avatar
i bought some lightweight 20s.. i may run short tyres with them im thinking of nittos DRs and gears are expensive! not only the parts but man the installation costs ALOT
the cam's powerband is 3100-6900 im sure of the 3100 but i think it maybe more than 6900
so will slicks give me a better time even if im not spinning now?
Old 12-05-2010 | 02:04 PM
iamkeniff's Avatar
it'll allow you to stall it up.
do you flat foot it off the line, or do you stall up? whats the rpm that you run? whats your 60'? what did you do to get the truck to not spin?
Old 12-05-2010 | 02:10 PM
Bumpers's Avatar
I wouldn't think spinning would be a huge problem with awd.. I would just borrow some shorter lighter wheels and tires and give them a try.. Then decide if you need slicks or not
Old 12-05-2010 | 02:23 PM
i stall it up to approxx 3k more or less i shift at 6500, 2.0 is my 60ft..
Old 12-05-2010 | 02:28 PM
iamkeniff's Avatar
whhhhaaaaa you stall to 3000 on stock street tires AND still dont spin? your shii wont get better than a 2.0 60'? man somethings wrong...head/cam/stall/tune being AWD i bet that thing should be 1.8 60'ing if it not spinning. try a shorter tire/lighter rim. i just cant believe that thing is going that slow with that much RPM
Old 12-05-2010 | 02:37 PM
well.. 1 wheel spins which is on the left but its for a split second only or is that consider spinning haha
Old 12-05-2010 | 02:46 PM
iamkeniff's Avatar
nope...thats bc the G80's arent staying locked.
damn son...i wish i could launch mine at 3k. also have you tried a flat foot?
Bumpers's Avatar
The front will squeel alittle because all the wait shifts to the rear when you take off ... I would try some lighter wheels and tires and as soon as you know the green lights coming on just floor it and flash the converter and see what that does
Old 12-05-2010 | 02:52 PM
i havent tried just flooring it but it feels slower to me going to try it out tomorrow
Old 12-05-2010 | 03:03 PM
iamkeniff's Avatar
try the flat foot and watch the 60'
then go to 1000rpm check the 60'
then go to 1500 and so one till you are at the max rpm. your 60' should change as you stall it up unless your truck would rather be flat footed. your 60' will determine it all. that 3600 should flash looser.
Quick Reply: Need a better 60ft!
