Need Help with my 07 Silverado
Old 05-07-2009, 09:30 PM
schino's Avatar
Originally Posted by Bo185
Should all be same as the 5.3l has flat tops now.
i think what he meant is the wrist pin location may be different. i guess you would have to look at stock 4.8 and 5.3 rods and see if the stroke size difference is the same as rod size difference.
**** thing is right.. but come on your not really a chick if you have 34a's
Old 05-07-2009, 10:07 PM
Where's the Beef?
viciousknid's Avatar
Originally Posted by Relentless07Silv
If im going to get a cam in i might as well do everything at once. Any and all help would be appreciated.
This sentence is my only real objection. A cam swap is easy peasy. A crank swap requires engine removal. Not exactly what i would consider similar in the fact that if you do the cam, you might as well do the crank.
Could go either way on the deal your looking at. If your going to pull it, you may as well get a 6.0 and just do it once. However if your on a budget currently, the deal you have isn't bad at all.
Old 05-08-2009, 03:05 AM
Banned
lucky77's Avatar
just go with 6.0 + 243 heads . . .
Old 05-20-2009, 01:17 AM
eid2021's Avatar
Your gonna have to blalance the rotating assembly
Old 05-22-2009, 06:57 PM
hulley's Avatar
+1 :d
6LITEREATER
01-26-2016 04:21 PM
nickpc82
11-02-2015 02:49 PM
85SS/85GN
08-07-2015 04:30 PM
Shtbox
08-02-2015 10:52 PM
Offroadunleashed
07-20-2015 02:25 PM
Quick Reply: Need Help with my 07 Silverado
