Need some advice, fix or just trade it in?
Old 10-04-2013 | 10:17 AM
TXsilverado's Avatar
they are a dime a dozen here in houston. pick any given junk yard around here and they probably have a dozen or more 4.8 and 5.3 engines. gen IV may be a little tougher, but not impossible
Old 10-04-2013 | 11:29 AM
00sierra72's Avatar
Default had the same issue different vehicle
I had the same thing happen to my car, non dod of course. If u do change out ur cam and lifter be sure to do an oil pump. We figured it was an oil related issue and the pump did have a lot of grooving on the rotors when I pulled the old pump apart.
Originally Posted by Holty
Hey guys, looking for some advice here.
Here are some pics, this is #6 intake and exhaust lifters and #6 spark plug. I'm sure this also will mean the cam is now junk.
Old 10-04-2013 | 03:51 PM
TIM Z's Avatar
11 sec. Truck Mod
That sucks Josh , might as well fix it while it's down , make it a more fun / reliable daily .
Damn DOD bullshit !! Thankyou govt for messing up a good thing .
What is exactly the failure , just the did lifters are that bad / poorly made ?
How many miles on this engine ?
Old 10-04-2013 | 11:21 PM
TechGM's Avatar
Registered User
Fix it. This was an early problem with some of the AFM engines. Cylinders 1,4,6, and 7 are the AFM lifters. Replace the AFM lifters with new ones. Also replace the lifter guides/retainers, whatever you want to call them. And put in a factory cam. If its a daily driver why go aftermarket? Then I want you to pull out the VLOM filter screen and replace it too. It's under the oil pressure sensor.
Tydriver
45
10-23-2015 09:19 PM
gaps
10-15-2015 02:53 PM
BCraven1018
09-18-2015 08:57 PM
muncie21
09-07-2015 09:55 PM
Quick Reply: Need some advice, fix or just trade it in?
