need some help guys
It's written in the tune to protect the transmission. It won't drop down into first gear under WOT unless your under 21 miles an hour. Even if you drop it into 1st manually on the column. You have to be under that speed for it to drop down.
The WOT 2>1 down shift tables are written in KMH and are 34KMH - 39KMH dependent on condition. Normal vs Tow Haul vs Hot.
34 KMH = 21.1266 MPH Normal
39 KMH = 24.2335 MPH Hot
If its not going into 1st from a stop and it starting in second gear, then there is a mechanical issue. Check your Linkages as mentioned including the indicator switch. If this doesn't solve your problem Let the trans guy trouble shoot it.
lxcoupe
07-21-2015 02:12 AM
