New cam setup. opinions please
Old 02-04-2014, 11:09 PM
fctry286's Avatar
Default New cam setup. opinions please
I realize this is my first post. But I will lay it all out.
The truck is a 2011 gmc sierra, 5.3l LC9. LT headers, CAI, Black bear tune.
I am going to do the VVT and DOD delete with a new cam. Howards 226/232
578/587@115. my question is can I use the LS6 behive springs and be ok? I was also told that I can use my stock pushrods.
Old 02-04-2014, 11:34 PM
fctry286's Avatar
Oh i have the 6speed and stock converter. Is this cam to much for my converter?
Old 02-05-2014, 12:26 AM
iamkeniff's Avatar
thats a donkey *** cam for a 5.3 stock converter stock gears stock compression.
look into something else imho. i vote mill the heads 025 an run a 040 head gasket with a vinci trucker high lift cam with pac1218s.
as for the springs they are rated at 575 max. so that cam would push them and cause early failure. put a set of pac1218s in it.
Old 02-05-2014, 08:58 AM
fctry286's Avatar
What do you mean donkey? I'm not looking into doing a bunch of stuff. I was just told that was a great cam. That's all.
Old 02-05-2014, 09:09 AM
its really too big for your current combo. Like Niff said, its big for a 5.3, stock conv. and gears. get u a 3600 stall and some 4.10s and it might would be fun.
Old 02-05-2014, 09:12 AM
look for something in high 21X on intake low 22x on exhaust. and to be safe, get you some dual springs. Brian tooley racing has a set for $219
Old 02-05-2014, 10:16 AM
NKPPhil's Avatar
It may be the greatest cam ever, with the right combination. Everything's got to work together, like these guys are saying. A great cam that only makes power above 4000 rpm will make your truck suck with stock converter and gears. Listen to these guys, they've been-there, done-that, got-the-tattoo.
Old 02-05-2014, 12:45 PM
fctry286's Avatar
So I talked to Howard's, he personally even recommended this cam. He said because the lobe separation is at 115. The computer will respond better and the stock converter will be fine.
I actually decided to go with PAC 1218 springs. So that's solved. Haha.
Old 02-05-2014, 12:52 PM
NKPPhil's Avatar
10-4, I wish you the best and please keep us up on your results.
Old 02-05-2014, 01:46 PM
fctry286's Avatar
Thanks will do.
Quick Reply: New cam setup. opinions please
