New cam setup. opinions please
Old 02-05-2014, 03:10 PM
jmgak47's Avatar
Then the guy you talked to is a dumbass...
You would be much better off with a smaller cam or you can learn the hard way. Your choice...
Old 02-05-2014, 03:38 PM
fctry286's Avatar
What size cam then?
Old 02-05-2014, 03:41 PM
ltr450ryder's Avatar
A 212/218 cam or a 220/220 cam
The trucker cam mentioned above is a 216/224 cam any of these will work but for a stock converter truck run a 212/218 cam
Old 02-05-2014, 03:44 PM
jmgak47's Avatar
The 212/218 high and low lift will be your top recommended picks for a stock converter truck.
Or go with a custom grind from a reputable source.
Old 02-05-2014, 03:58 PM
fctry286's Avatar
What about either of these two.
210/214 595/598 @114. Or
216/224. 551/551 @ 114
Old 02-05-2014, 04:00 PM
fctry286's Avatar
Also found a 218/218 604/604 @ 113???
Old 02-05-2014, 04:03 PM
that cam would give you good torque.
Old 02-05-2014, 04:06 PM
the 216/224 551/551 is the vinci trucker. Its cut on a 115 lsa though from VHP. both of those cams would be fine. IMHO, i wouldnt go any bigger than the trucker w/ a stock converter
Old 02-05-2014, 04:32 PM
fctry286's Avatar
Cool ok. I will go with that then. Sounds like a lot of people like them.
Old 02-05-2014, 05:00 PM
iamkeniff's Avatar
the trucker cam with more compression will work well with an oem converter and a 6spd. 6400-6500 shift point and itll stay in the power band.
the 212 218 is the smallest i will go. the truck will run out of steam with anything smaller.
i agree with whoever you talked to is just trying to blow smoke. that big of a cam even on a 115 will be a turd below 4k.
dont look for the biggest cam you can run...look for a medium tq style cam that will produce hp but have tons of tq down low to push that tank.
please stay away from the 220/220 cam...thats a cookie cutter cam that everyone runs. if you want that cam go with a different lift and lsa along with maybe some advance in it with a stronger cam grind.
Quick Reply: New cam setup. opinions please
