new vibration from driveline
Old 11-25-2013 | 09:49 AM
landon1405's Avatar
Default new vibration from driveline
so i just installed a 2/4 drop on my 07 ccsb 2wd sierra and everything went together easy as can be. took it for a test drive and have noticed a very slight vibration every so often when i am at a cruising speed and have to apply throttle to maintain speed. it does have its more noticable moments when pulling a hill but each out take has only lasted maybe 3 secs at the most. any ideas on what i should do?
Old 11-25-2013 | 10:02 AM
landon1405's Avatar
Old 11-25-2013 | 10:06 AM
Chevy_King1500's Avatar
check your pinion angle
Old 11-25-2013 | 10:38 AM
landon1405's Avatar
we was thinking it might be that, but do they make shims for my body style. all i was seeing is the ones for the classic body
Old 11-25-2013 | 11:33 AM
Noah Burns's Avatar
yep, pinion angle. a shim is a shim is a shim...
check out suspension source
Old 11-25-2013 | 11:51 AM
measure the width of your leaf springs and choose your shim
Old 11-25-2013 | 12:13 PM
landon1405's Avatar
ok last question i see 1 to 4 degree angles about how much do you guys think i need. like i said before is almost not even noticable but every once in awhile.
Old 11-25-2013 | 07:15 PM
Noah Burns's Avatar
Once I get my lowering parts thrown on mine (hopefully it warms up enough to do it soon) I'm going to shoot for 3-4 degrees on mine. David Wolfe says to shoot for that with these kinds of non solid mounted setups so that's where I'll start.
Old 11-25-2013 | 08:01 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Just buy a cheap angle finder and see what the difference is between the pinion and the drive shaft. There like $5 at Harbor Freight. Angle Finder w/ Dial Gauge
That's the only way to truly know what you need.
Old 11-25-2013 | 09:00 PM
AUTOT3K's Avatar
exactly this.
buying a shim and hoping for the best is a terrible idea but remember you dont want the angle to be the same as the driveshaft either
Quick Reply: new vibration from driveline
