Nitrous ?
Old 04-30-2013 | 04:54 PM
LT-1 SS's Avatar
Default Nitrous ?
I have been thinking of adding a 100 shot. I am tuned, no cats, corsa, and cai. with just switching to tr-6 plugs do yall think i will be ok and get by with a 100 safely. I do have hp tuners and when i get it figured out i will be able to tune for the nitrous just not intially.
Old 04-30-2013 | 05:47 PM
slowswb's Avatar
how timing is in the truck now? 20 degree with 100 shot you would be ok. I wouldnt use tr6 they will break up when spraying it. you would get a set of br7ef they a protected tip plug. You need to read the plugs change your fuel jetting from there.
Old 04-30-2013 | 07:14 PM
dirt track racer 81's Avatar
What that guy said.. Do some some reading on how to read plugs and making fuel changes
Old 05-01-2013 | 09:27 AM
nonnieselman's Avatar
What i always did was just pull 4* if your goin to spray 100 shot, If its running good with no detonation.
Old 05-01-2013 | 11:39 AM
LT-1 SS's Avatar
thanks for all the info but i just ordered everything to do the ls9 swap instead of a 100 shot, for now anyways
Old 05-01-2013 | 12:17 PM
Phantom's Avatar
11 Second Club
I ran 100shot with tr6 plugs and no timing pulled on 91 octane for years. Pull a couple degrees and you should be fine. Not much to worry about with that little bit of nitrous
simman22
01-21-2017 10:27 PM
gavin2005
09-13-2015 09:04 PM
06 4.8
09-11-2015 10:36 AM
gmcyukon
09-07-2015 08:46 PM
06murder
09-04-2015 03:54 PM
Quick Reply: Nitrous ?
