NNBS 08 CAM issue!
Old 12-01-2009, 03:01 PM
jsussilverado's Avatar
Default NNBS 08 CAM issue!
i installed a comp cams 219-233 thumpr cam and i have the following issues!
-CAM SENSOR
-SOME RANDOM MISFIRING
-1 BANK LEAN
so the stocks injectors will get me through or i will have to upgrade the stock ones.
the truck its a little heavy between idle and 2500 aprox.. it requires a little gas to start correctly! i think its run worst than stock!
i have an appoinment at my nearest diablosport CMR for some custom tuning
Old 12-01-2009, 03:31 PM
Tootall's Avatar
you truck came with a single bolt 4x trigger cam gear . . . did you use a 4x trigger cam gear with the new cam?
random miss fire is a given
1 bank lean . . . that's from not being tuned . . . don't go out and start beating on it.
Old 12-01-2009, 03:47 PM
iamkeniff's Avatar
stock injectors are fine.
your truck needs to be retuned. go with EFI Live please..i dont think the Diablo programmer can do as much as EFI Live/HP Tuner, but then again im not a genius..so do as you please.
in your cam process...did you change lifters, and valve springs?
whats the exact specs of the cam. id like to know what other mods you have vs just a cam.
what motor
what gears
do you have a stall
did you put LTs (long tube headers)
did you upgrade your pushrods
just questioning the install for educational purposes.
did you go back with a 1 bolt cam an reuse your stock sprocket?
did you line your Dots up? that way the timing isnt off?
Old 12-01-2009, 04:25 PM
i used the stock sprocket modifying it to fit the Three bolt pattern! we use DOT to DOT to make the install, i modify it becouse im from Venezuela, here we dont have LS7s but i will order the LS7 sprocket soon!... i shoud mess with the TIMING when i get the tune.
so the random misfiring i shoud consider it normal...
in the comp cams page says it will fit stock converter. or i will need one!
My truck its a 5.3 3.73 WITH G80! with
-Edelbrock Shorties , True duals with flowmasters, deleted cats
-Throttle body spacer
-k&n intake
-125 HP Wet Nitrous kit
-not installed yet 4L60E TRANSGO HD2
-Diablosport U7194 with Lastest release Tune.
runing great on stock lifters NOT DOD lifters. and pushrods
sorry about my crappy english!
Old 12-01-2009, 04:28 PM
Formerly darynC-10/23/10
Daryn's Avatar
take off your throttle body spacer thats not worth anything, and if you will be doin your own tuning, i suggest you read the stickys in the tuning section
Old 12-01-2009, 04:38 PM
i think i will do my own tuning using a AEM WIDEBAND.
Old 12-01-2009, 05:10 PM
iamkeniff's Avatar
no problem man!
i wish my fn truck came with NORMAL lifters lol.
ill never tune my own truck...im better turning wrenches vs tuning lmao
Old 12-01-2009, 05:31 PM
.. im just the opposite to that ! LOL! what size are the 5.3 stock injectors! and how many GPH is the fuel pump if someone knows!
and i should get a stall.. or im Ok! (if i need to get a stall, every LS 4L60E Converter should fit in my 08 nnbs)
im looking for 14s low to high 13s without NOS!
using 275 55 17 rubber
Old 12-01-2009, 05:45 PM
iamkeniff's Avatar
better do gears, a 3000-3200 stall, Billet servos.
get rid of the shorties an upgrade to LTs imo
do you have a reg cab? extended cab, crew cab?
i have a CC an i got 15.6 outta it with LTs, OR-y, Tune with no stall, no shift kit, stock 3:42/G80
3000/3200 stall
Billet Servos
4:10s you'll see mid 14s with a CC maybe lower
Old 12-01-2009, 05:51 PM
iamkeniff's Avatar
219/233 @ 50 .553/.536 109LSA is that the cam you have?
dude IMO the 109 is bad *** but not for a DD, i woulda done a 112
the .553/.536 should have aftermarket valve springs, i could be wrong..im normally wrong lol
i dunno if that cam would work best with a stock converter. id go with a 2800-3200 stall
Quick Reply: NNBS 08 CAM issue!
