NNBS 6.2l in RCSB project
Old 02-18-2012 | 12:52 PM
Robert91RS's Avatar
Too much extra work for no reason imo. Plus the only way to get the 6l80 you want is in a 5.3 truck, the 4.3s and 4.8s never got them.
Old 02-19-2012 | 06:05 PM
Banned
geez been doing some more research and apparently the going from a 2WD to a 4WD setup is possible but is a lot of work, and im not adding that to my list. So it seems the best bet is to find a high mileage 4x4 with a 4.8/5.3 and use that as the base for this project.
Old 02-19-2012 | 11:38 PM
Bowtie502's Avatar
Originally Posted by Robert91RS
RCSB 5.3 4x4 WT may be hard to come by. Any of the 6.2s will work but if you find a LS3 you won't have to wory about it having AFM lifters like some of the early L92s did.
sorry for the offtopic question, but could you explain what the AFM lifters and what the problems were please?
Old 02-20-2012 | 12:13 AM
iamkeniff's Avatar
AFM/DOD. you need to change the lifters to run a non AFM/DOD cam. Which causes you to have more money in the lifters, head gaskets, head bolts.
The LS3 will need the oil pan, pick up tube, crank pulley, and your acc to work. Also you would run into some trouble with the intake possibly.
5.3/6spd 4wd is the way to go, then put the 5.3 in the garage and save it for a rainy day.
Old 02-20-2012 | 05:33 AM
ITSAGAS's Avatar
Why not go with a 2wd and add an air locker? If your ony ging to do some occassional "light" offroading, only one set of gears to buy then! Also why not a standard tranny? Then really mix it up and put the setup in a '65 shortbox!
GXPJAY
02-13-2022 08:15 AM
chopperloco
07-10-2016 10:45 PM
rednekferlife101
32
01-08-2016 10:42 PM
livefast1
09-25-2015 07:31 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: NNBS 6.2l in RCSB project
