No oil pressure and knocking noise???
Good afternoon L&G's,
I recently started hearing a little tapping noise but i looked at the oil pressure it was fine but still been playing close attention to it. So this morning i started the truck this am and the knocking noise was louder than usual when the chime went off i noticed it was pretty loud then it displayed low oil pressure when I looked at the dash it was displaying no oil pressure so i turned it off quick... I am really worried i hope I didn't mess up my engine. Could it be my oil pump? Please help thanks!
Custm2500's Rude Friend
Low oil or no oil usually takes out the cam and/or the lifters on these trucks.
Sometimes it will spin the cam bearings and some times it will cause a lifter to fail.
One way or the another you will have to either let some one diagnose it or tear into it and see what you can find.
Thanks! I am going to do an oil change this weekemd the see if i see anything in the oil and i will cut the filter as well...
Update: so bite the bullet and pulled the block apart and like my mechanic said it was the first lifter on the driver side and it had some damage to it... Also the came suffered damage so i went ahead and ordered ALL bearings new, Cam, every last seal/gasket, piston rings, one motor mount was bad to i bought both brandnew, oil pump, and water pump. According to the dealer cam and bearings are different in order to avoid what happen. It was a recall on these engines therefore problem has been corrected and i can really tell the difference in the bearings because the hole is way smaller then the original OEM one.
Well i was told it was. Common issue with the LC9's due to it shutting down 4 cylinders on highway... As per the mechanic and dealer the cam has been changed because of that issue as well as the bearings the hole on them are smaller so it builds more pressure and lubricants better.
