Noticed a clicking noise after drop spindle install (4wd)
Whoa- time out! whaddya mean cut the lower ball joint? Is that referring to grinding the stud down? I only plan on 17 inch wheels, maybe 18's if there's a real advantage in the larger size...............
you have to cut the ball joint down to the nut or it'll rub on the inside of the wheel. mines 1/8" away from the nut and it has a lil low spot that touches the rim a little. i have 2" Belltech spindles/2" Autozone drop shackles, and removed the lift block. i can get you some pics after it's cleaned up...the truck is DIRTY as hell.
clicking? huh um center cap broke, sensor broken, if he tire pressure sensor is on the inside of the wheel it might be hitting something it happens, when does it start clicking when you turn/rolling/etc.
