oil pan removal
oil pan removal
Okay I need to drop my oil pan I took off all the bolts and.the tube but I cant seem to.get it down the front crossmember seems to.be blocking it .. what is all needed to be done to completely remove the pan
you don't have to drop the steering rack, just that one line, its a 10mm bolt.
remember to take out the 2 bolts threw the timing cover, and the 2 threw the trans. you do have to drop that cross member, I think its a 21mm wrench and socket
pound out those factory rivets (if replacing the gasket) and remember to silicone bead the 4 corners (not excessively)
SlvrSierra4.8
10-01-2015 09:39 PM
